delta dp350 drill press
  • delta dp350 drill press
    i realize this is not a ridgid question, but there are alot of smart people on this forum so i thought i would ask. the delta drill press will not work. i checked the switch with a multimeter...the hot(black) side, works the white(neutral) does not. the switch is DPST. am i correct in thinking this is why the drill press does not work? the neutral side is open? just want to make sure i am looking at this correctly. thanks
    rjherald
