Can the Wet/Dry Vacs top compartment be cleaned with water?
  • Can the Wet/Dry Vacs top compartment be cleaned with water?
    Hey guys. Just purchased a 16 Gal Wet/Dry Vac (model WD1637). Using it to pump out liquids/solid waste. After using it for the first time, we need to clean it... or rather we need to clean it every time we vacuum liquid waste. We hose down the filter (I bought a wet filter) and inside parts, but I was thinking, can we hose out the compartment that has the motor?
    It's the top compartment that has the hose attachment... I figure it would smell from the waste if we didn't clean a little bit of there. Would this be okay?
    Thanks!
    Re: Can the Wet/Dry Vacs top compartment be cleaned with water?
    How about taking a rag with disinfectant and wiping it down!
    If you get water into the motor housing your next post here
    will be complaining how the motor burned up and failed!
    Cactus Man
