EB44240 Fan
  • EB44240 Fan
    I purchased a used EB44240 Oscillating Edge Belt Sander. I replaced the fan as the one that come with it was trashed. However, it doesn't sit right in the unit, and I can't use the belt sander with it in. The BE44240 has a retaining ring on the motor shaft that is absent in at least the EB44241. It seems that it was replaced by bushing.
    Question: Can I replace the retaining ring with a bushing on my EB44240?
    Re: EB44240 Fan
    According to the eReplacementParts website, fan part #830291 replaces an obsolete part number. If this is the part number you purchased then maybe you need to remove the original retaining ring, as that part was also discontinued, and install the fan without the ring.
      Re: EB44240 Fan
      I have an older EB44240 and a brand new EB44241 (3 hours old).
      The older model has a retaining ring to support the fan and drum. The older model's oscillating shaft is indexed for the bushing at the top end of the metal drum (inside the belt sanding unit) to make the drum spin.
      These bushing have the bad habit of capturing the threads (on the oscillating shaft) and rendering the belt sander impossible to remove.
      Ridgid redesigned this area with a pin thru the motor's shaft (that the fan now indexes to) and then the drum in the sanding belt indexes to the fan. Eliminating the need for a bushing entirely.
      Now that the bushing for the older model is no longer available, if the above happens, you are forced to fix it somehow or buy a new unit. I just bought a new one. I don't believe that you can use it w/o the retaining clip. Maybe a stack of washers? Please be safe.
      Hope this helps!
        I know this is an old thread, but I have also just purchased a EB44240 unit that appears to be unused. I tested it and it ran before paying the Craigslist seller. I noticed that this first edition model does not have the removable knob above the drive drum like on the newer models. The exploded diagram above has helped a lot.
        Here is the issue. Inside the main plastic body, I found a new looking spring rattling around. From the parts diagram, I would bet it is item 15 above, the swivel spring.
        How complicated is it to take the sander apart to reinstall this spring? I'm pretty handy, but the machine looks like it needs to come apart and go back together in the proper sequence. Can anyone help? If I have to send it to a repair station, it is not going to be worth fixing, I suspect.
        Also, is it common for the early units to have faded from grey to a vile mustard color?
        Thanks in advance.
