pneumatic jobmax
  • pneumatic jobmax
    pretty cool but like the corded version, i wouldnt use.
    Pneumatic JobMax Multi-Tool Kit-R9020PNK at The Home Depot
    in the description it says 7 tool heads? Whats new i wonder?
    Re: pneumatic jobmax
    The ridgid rep said a reciprocating head and I believe a cut off wheel head. Now they just need a rotory head tool as well as a grinder attachment maybe even a tin shears!
      mini circular too. Id buy all, im a junkie
        at 18.2 cfm of air, where can this tool operate other than a home garage with a large compressor tank.
          18.2 cfm @ 90 psi is a pretty hungry tool. there are not that many compressors that will keep up with this tool, but it is an intermittent use type tool, you won't be doing long periods of on time I would not think. Still, I wonder if that's a typo as their web site is full of inaccurate information like this. need to check the manual and see what it says.
          "It's a table saw, do you know where your fingers are?" ? Bob D. 2004
          http://www.cordlessworkshop.net
          https://youtube.com/@bobd.
            I think its more or less targeted as the "shop" version of the tool.
              i agree i think its a typo knowing home depot
                That is a bunch of air but the Ridgid manual says the same
                Air Consumption at 100% Duty Cycle.................................18.2 SCFM at 90 psi
                  you have it already?
                    all it needs is a portable air compressor,
                      Nice BHD, is that something you put together?
                      Could my little baby tractor spin it?
Name:	IMAG0896 (Large).jpg
                        IT is not that huge of a compressor, about 50 cubit feet a min and about 120 psi, I think if electric it would take a 15 hp motor, but I think your tractor would operate it,
                        the compressor was from a sugar beet thinner that my son scraped out, (one company tried to make a pneumatic beet thinner) to replace the need for immigrant workers, to hand thin the beets, they were not that effective I was told, and the tank is a propane tank trailer, (I guess the home land security is not happy with the tank trailers and I was able to buy it very low cost from a propane suppler), they were popular with propane powered tractors (one company Minneapolis Moline made a lot of them in the 60's and early 70's) and they were sold around here,
                        it took some looking to find the proper items to make the unloader work but I left the safey valves the propane tank had, and added ASME saftey valves to it as well, that can dump about thee times what the compressor can produce,
                          It is on the HD site under the more info tab
                            Attached are some guidelines for the output necessary to run the JobMax Air. Hopefully this helps clear up any confusion. Please let us know if you need more information.
                            ThanksR9020PN_937_Compressor Air Requirements.pdf
