Where can I get a Dado throat for saw
  • Where can I get a Dado throat for saw
    Does Rigid make a dado throat plate for the r4512 10" table saw? If so where can I find any other accesories for this saw?
    Re: Where can I get a Dado throat for saw
    I do not have a Ridgid saw, but on both of my old table saws, I just make my own throat plates, (similar to making a 0 clearance plate but with a larger opening in it)
    Buy LEECRAFT RIDGID R4512 Table Saw Zero-Clearance Dado Insert at Woodcraft
    Zero Clearance Table Saw Inserts - Rockler Woodworking and Hardware
    Amazon.com: New Ridgid Zero Clearance Insert - 2003/2004 by Peachtree Woodworking PW949: Home Improvement
    if you get your manual I would guess there would be a part number and by putting that part number in google most likely one would find some thing, if not what I found above was off a quick google search and it looks like amazon has a few different units, (not sure of the numbers, but like I said making one is not that hard,
    On one of my saws it is out of 1/8" plate and the other saw a old Rockwell I make them out of 1/2 particle board, or ply wood,
      I make my throat plates from laminate flooring scraps or samples.
      How To Make A Zero Clearance Insert | Woodworker's Guide
