1 yr old RD8000G using way too much oil. 1qt every 24hrs.
  • 1 yr old RD8000G using way too much oil. 1qt every 24hrs.
    I was told by a tech that the reason this generator is using so much oil is due to not running it at 80% load long enough for the rings to seat. Is there any truth in this? And what else can I do to correct this problem. It goes roughly 24 hrs before I have to add oil using sae40 oil.
    Re: 1 yr old RD8000G using way too much oil. 1qt every 24hrs.
    Compression test ?
