Oil level in Rigid 3000 psi washer
  • Oil level in Rigid 3000 psi washer
    I have a rigid 2.6 3000 psi pressure washer. When I pull the dipstick to check the oil there are 2 hash marks. 1 on the bottom and 1 near the top. The manual says the oil should be up to the hash marks. Which one is it referring too.
    Thx
    Re: Oil level in Rigid 3000 psi washer
    Thx
    Top.
    Oil should be just about to the point of running back out of the engine.
