TS3650 stops at approx 36 degrees
  • TS3650 stops at approx 36 degrees
    Have TS3650 and it binds somewhere when I try to adjust to 45 degrees. I have read the owners manual and checked all the things it said. I cannot see anything binding. At around 36 degrees, it binds and starts to pull in the side panel.
    Thanks,
    Re: TS3650 stops at approx 36 degrees
    Are you using a zero clearance table insert? Have you checked for sawdust build-up?
      this issue has been discussed here before. Search for TS-3650 and you should find a number of threads with solutions to your problem.
        make sure the bevel lock has been sufficiently loosened.
          you're right, that's another possibility.
            I will search here more. I have cleaned, taken bevel lock off, checked angle set screw. Will keep looking.
            Thanks,
            Dale
              Make sure there is no build up of sawdust in the trunions.
              SSG, U.S. Army
              Retired
              K.I.S.S., R.T.F.M.
                You may find some help in this old thread too. I think it was mentioned in here at one time.
                https://www.ridgidforum.com/forum/t7585/
