R2600 Orbital Sander Stops With Pressure
  • R2600 Orbital Sander Stops With Pressure
    My 2600 Orbital Sander stops with any amount of pressure. I have read it may be an O ring or a bearing. Does anyone have first hand experience with this and can it be repaired?
    Re: R2600 Orbital Sander Stops With Pressure
    I'm not sure of what the component is, but certainly it can be repaired. Are you still within the 3-year warranty period or better, did you register the tool for the Limited Lifetime Service Agreement (in which case, you are covered forever)?
      Mine did that. Twice.
      Repaired under warranty both times, I forget the "issue". It may be a bearing.
      Shortly thereafter, the circuit board needed replacement.
      Ridgid has a lot of $$ into my sander at this point...
