R7100 Drill
  • R7100 Drill
    Tried to use my R7100 drill this morning without success. It was working find the last time I used it and has never given me problems. I rarely use it, it's been well taken care of and I haven't dropped it or damaged it in anyway. The power cord is lit, but I pull the trigger and nothing. I pulled the handle casing off and made sure all the visible wires were in tact and connected.
    Any help would be great appreciated.
    Thanks
    Scott
    Re: R7100 Drill
    YAG, you have power, wires are all connected, pull the trigger and nothing..........bad switch.
      Re: R7100 Drill
      ... or brushes worn beyond their service limit.
        Re: R7100 Drill
        Make sure the "directional switch" is set all the way to forward or reverse. Also did you try spinning the chuck by hand and try again?
