Sawzall blade recommendation for cutting 4x4 PT and round fence posts?
  • Sawzall blade recommendation for cutting 4x4 PT and round fence posts?
    can anyone tell me what the best sawzall blade would be for cutting the above mentioned wood? I ordered some of the Ugly blades for pruning but not sure they are good for the posts above. If they are, good, b/c i just ordered one but if not what do you suggest? thx
    Re: Sawzall blade recommendation for cutting 4x4 PT and round fence posts?
    those are good, but a chainsaw is easier
      A demo blade will last quite a while and if you hit earth and dull the blade it will be cheaper than re-sharpening or replacing a chain saw chain.
        Can you just run a circular saw up one side and down the other? I prefer a rip blade for PT, and I REALLY like the Teflon-coated blades. If you're going with a reciprocating saw, I like a 6 tpi blade, but I don't like a variable pitch blade for PT. It's too slow and it can hang up more than a fixed-tooth blade.
        Dan
          I have used the pruning blades a few times for this work. I have a bunch (50+) of PT landscape timbers used as edging around flower beds and they need to be replaced every few years. I use my cordless recip saw with a pruning blade, works fine. I have also used my cordless circ saw but battery life is not as good. I get more cuts out of a battery with the recip saw.
