R4512 blade wrench does not fit
  • R4512 blade wrench does not fit
    I just setup my R4512. When I went to install the blade, the open end blade wrench that goes on the inside of the blade to tighten it does not fit on the inner nut. It also does not fit on the blade nut, which I'm assuming should be the same size. Has anyone else had this problem? It seems like I could just take a file to the inside of the wrench blade, but I'm hesitant to do that before I hear that I'm not crazy
    Thoughts?
    David
    Re: R4512 blade wrench does not fit
    call ridgid CS and have them send you a new wrench. you bought a new tool, everything should work properly, including that little wrench.
