TP1300 Planer Leaves Ridges
  • TP1300 Planer Leaves Ridges
    My TP1300 planer is leaving two parallel, light, raised ridges. I figured it was a nicked blade. I checked and couldn't find any nicks. I changed the blades anyway and still have the problem.
    Any suggestions?
    Re: TP1300 Planer Leaves Ridges
    Are these ridges in the line of travel or perpendicular to the direction of travel through the planer?
    The first would most likely be a nick in a blade as you said, the latter might be misalignment of the blades, that is not all the same height so that they leave a series of slight cup marks on the wood.
      They're line of travel, slightly raised and a little fuzzy looking, about 1/2" apart, a few inches left of center. I assumed they were blade nicks until I changed the blades despite not finding any nicks in the old ones, and they didn't go away.
      I'm going to crank the head all the way up so I can try to take a look at the rollers and blade assembly. That's all I can think of to do at this point.
        There may be something wrong on the out-feed roller. Maybe there is some buildup or something that is causing those marks after it is cut and passes under the out-feed roller.
          I thought I replied and was told a moderator would approve the message, so I'm trying this to see if it shows up.
            I checked the outfeed roller. It was moderately gunked up so I cleaned it and the infeed roller.
            In the process I noticed regularly place flash on the aluminum casting that in front and back of the rollers. I cleaned off some of that.
            As a result I'm now getting parallel scrapes about half an inch apart all the way down the length of my boards.
