Problematic Blade Collar on a MS1290LZ (12" Mitre Saw)
  • Problematic Blade Collar on a MS1290LZ (12" Mitre Saw)
    Hello
    I recently purchased this saw and today had to change the blade. There seems to be a problem with the blade collar as it will not slide on to the pin as it should. It seems that what should be the flat edges on the inner opening of the blade collar come too far in. Had any one else had problems getting the blade collar back on when changing a blade? The other blade was installed by the manufacturer and has some wear marks on it which seem to indicate that something was rubbing it the wrong way. I am not sure how snug this should be and how much I should be forcing it on or smoothing the problematic edges down.
    Thanks
    SE
