Weak table saw
  • Weak table saw
    Bought a rigid ts 3612 10in contractor saw off of Craigslist, it has trouble cutting 3/4 softwood with a brand new narrow kerf blade. Belt dressing helped just a bit. The saw is in use on the same outlet where an old craftsman saw was in use and worked well so I know my power supply is not in question. Help?
    Re: Weak table saw
    Hate to say it , but that's probably why its on craigslist.
      Re: Weak table saw
      What's the condition of the cord on the saw? I'd start troubleshooting from the outlet first. Could be the cord need replacing, or the connection to the motor could be loose. That could cause current loss.
        Re: Weak table saw
        I would also check to make sure that the motor is mounted properly. If it isn't, the belt may not be tensioning correctly.
        ------- Henry Ford
          Re: Weak table saw
          is the belt tight?
          does the motor slow or just the blade?
          dose it trun freely by hand when off?
            Re: Weak table saw
            here's the OM for that saw, which is one of the best 10" contractor saws ever built:
            http://www.ridgid.com/ASSETS/88E7884...le_Saw_Man.pdf
            i'd step through the set up procedures. it's probably due to the motor mount not being employed properly, as has been previously noted.
