Loose belt on oscilating / belt sander
  • Loose belt on oscilating / belt sander
    I have seen a variety of videos demonstrating this sander. Every video demonstrates belt sanding with copious amounts of sawdust being created. On my machine(model EB44242), the least amount of pressure to the belt causes the belt to stop. Additionally, the belt migrates up the roller. The belt seems to need tightening. What is the process? Thanks
    Re: Loose belt on oscilating / belt sander
    The procedure you're looking for can be found on page 21 of your Owners Manual.
    ------- Henry Ford
      Thanks for the help. With the tensioning lever in running position and one hand at each end of the sanding belt assembly, I can easily slide the belt off the drums. This has been the case since the machine was purchased. Thanks again!
        In that case then I think that the problem may well be the sanding belts themselves. Probably just a bit to big. I just checked my EB4424 and the belt doesn't move at all when tensioned up.
        ------- Henry Ford
