Power Tool Dimensions
  • Power Tool Dimensions
    I was looking around the web site and was wondering Why don't any of the tools have their dimensions posted in the spec sheets? This would be handy to have if you are trying to find cases for your tools.
    Thanks
    Phil
    Tools Rule
    Re: Power Tool Dimensions
    I know what you mean, maybe if several of us ***** about the lack of dimensions we might see some change.
      Perhaps,
      But if you need a case for your particular tool, then can it be presumed that you actually have that tool and thus might also own a tape measure?
      Question of course would be whether it is easier to log on and look up the dimension or to just measure it.
      But really, as a guy who spent a career communicating product information to technicians and consumers, providing specifications including dimensions and weight is very basic.
        I could see where you might not have the tool yet but are needing to know its dimensions or weight. These are things I need to know when planning work sometimes. How much storage space is needed to carry all the tools that will be used and how much will that tool box weigh with all the tools in it for shipping and for rigging purposes.
          I went to the Home Depot website and for example downloaded Ridgid
          4 1/2" angle grinder.
          Looking at the product specifications I came across DIMENSIONS!!!!
          PRODUCT DESCRIPTION
          RIDGID introduces the 4-1/2 in. Angle Grinder with SlimGrip that weighs less than five pounds making this lighter weight design easier and more comfortable to use. This tool is the first angle grinder of its kind to the market. The compact size makes this grinder perfect for use in confined areas. This new innovative easy to use angle grinder is the new must have tool on every job site. Backed with the RIDGID Lifetime Service Agreement. Free Parts. Free Service. For Life.
          7 Amp motor for powerful performance
          SlimGrip Handle Design - Provides maximum grip comfort during daily use
          Lock-on Button - For ease of continuous use
          Spindle Lock - For easy wheel changes
          CLICK HERE TO REGISTER YOUR RIDGID PRODUCT.
          MFG Model # : R1005
          MFG Part # : R10051
          Return To Top
          SPECIFICATIONS
          Amperage (amps) 7 A Arbor Size 5/8-11
          Assembled Depth (in.) 17.32 in Assembled Height (in.) 5.9 in
          Assembled Width (in.) 4.37 in CSA Listed No
          Color Family Orange Cord Length (ft.) 8
          Corded Tool Type Angle Grinder Cordless/Corded Corded
          ETL Listed No Manufacturer Warranty 3 Year Warranty Lifetime Service Agreement with registration within 90 days
          Maximum Speed (rpm) 10000 Power Tool Product Type Corded
          Product Depth (in.) 5 in Product Height (in.) 3 in
          Product Weight (lb.) 5 Product Width (in.) 13 in
          Reconditioned No Returnable 90-Day
          Side Handle Yes Spindle Lock Yes
          UL Listed 1-UL Listed Variable Speed No
          Wheel Diameter (in.) 4.5 in
          AND..here is an 18V drill with its specifications.......
          PRODUCT DESCRIPTION
          When you need a drill that has the highest power to weight ratio, look no further than this offering from RIDGID power tools. This most compact drill in its class also boasts the most torque in its class so you can drive the largest screws home all day long with little worry about fatigue. It accepts any 18V RIDGID battery, using lithium-ion batteries for maximum performance.
          1.5 Amps lithium-ion batteries for twice the run-time
          1/2 in. Single sleeve locking chuck holds bits securely
          2- Speed transmission right power to complete the job
          24 Position clutch finer adjusment and repeatability
          Batteries and Charger Sold Separately,this item works with these batteries (AC840083, AC840085, AC840084 and AC46182) and chargers (AC470013 and AC840093)
          MFG Model # : R860071BN
          MFG Part # : R860071BN
          Return To Top
          SPECIFICATIONS
          Assembled Depth (in.) 8.582 in Assembled Height (in.) 9.055 in
          Assembled Width (in.) 3.543 in Batteries Included No
          Battery Size Lithium Ion Battery charge time (min.) 45
          CSA Listed No Charger Included No
          Chuck Size 1/2 In. Chuck Type Keyless
          Clutch Setting 24 Color Family Orange
          Cordless Tool Type Drill/Driver Cordless/Corded Cordless
          Maximum Speed (rpm) 1500 Power Tool Product Type Cordless
          Product Depth (in.) 8.582 in Product Height (in.) 9.055 in
          Product Weight (lb.) 3.86 Product Width (in.) 3.543 in
          UL Listed 1-UL Listed Variable Speed Yes
          Voltage (volts) 18 V
          Cactus Man
            I'm so glad we've got something new to gripe about.
            I was bored with the old stuff.
            I propose we also gripe that the tool inspectors name isn't included in the kit.
