R350CHE Air Leak after first nail!!
  • R350CHE Air Leak after first nail!!
    Hey fellow craftsman.
    Just bought a Ridgid R350CHE Framing Nailer. After setting my pressure to 95psi as recommended, I wanted to adjust my depth before use. On some scrap 2x4 I placed the first nail, then POOF!, an air leak straight down the pin shaft. Now it no longer works.
    So any ideas fellas? Or just take it back to HD?
    Re: R350CHE Air Leak after first nail!!
    Sounds like an o-ring failed. Guess if it was me I'd probably tear into it to investigate, but thats my odd inclination on stuff like that. Smart thing would be to exchange it probably. Did you disconnect the air, and then try it again?
      Well the saga continues...I took it back to HD and exchanged it. Tried the new one. Again, first nail started another air leak!!! This is just not right? This should work out of the box with only minor depth adjustments.
