This is the R29302 kit with R2901 motor, R2911 fixed base, and R29202 plunge base that's discontinued here in the US but still available in Canada.
I bought this router last year and today I pulled out the plunge base to use for the first time. It is increadably stiff to the point of unusable. Pushing down it would get stuck and not easily have to be pulled back up. Yes the locking lever was unlocked.
I've removed the locking lever and screw so there is no tension on the tubes. Removed the 2 top caps and 2 internal springs then managed to pull the router clamp off the base and tubes. It's almost as if the tubes are spread but using a set of calipers everything looks straight. Cleaned, degreased, checked for burrs and tube deformations, etc and all is good.
Gave the tubes a spray of Fluid Film (a lubricant) as well as inside the clamp tubes. Slid one clamp tube down over the base tube and slid them a few dozen times up/down and then the other side. Both moved freely. Then slid the clamp tubes down over both base tubes. Bit tight but much better. Reassembled the plunge base with springs and while I'm now able to move it up/down its still far from smooth. It jerks when starting down, smooths out then fetches up again sometimes while other times it'll slide down fully. At least it springs back up every time now!
Anyways.. Anyone else have any issues like this or heard of it and perhaps have a solution? I'm going to disassemble the entire thing, clean and relubricate it again and see how it is then.. after dinner. After that I see either wet sanding the base tubes slightly or honing out the clamp tubes unless someone has another idea.
I don't have the warrantee since I bought it in Canada last year and was told I couldn't get it here in the US. Router works great in the fixed base and my ears love the relatively quiet operation of this poweful router. Hopefully I can get this resolved.
