Compact routers
  • Compact routers
    Looking for a new compact router kit with plunge capabilities. Dewalt and Makita make one.
    Any one care to offer some guidance on the plus / minus of each brand?
    Re: Compact routers
    I'd feel good about either. If I was buying I'd check ratings on a few sites just for confidence and settle on the best deal I could find.
    I know.....I know.....lots of help.
    A quick look online helped me out. The makita set is considerably more expensive but contains more accessories. It would boil down to whether I could use all of those accessories or not.
    The porter cable set looks to be the same as the dewalt also. Just in case you run across a deal there.
    2nd edit
    If I could afford it I would go with the makita kit that includes the offset and tilt base as well as the fixed and plunge. $70 for a much nicer kit. You might not think you'd use those, but you never know what you'll use until it's an option.
      Re: Compact routers
      The PC is single speed I think, or at least the first generation was. The DeWalt is variable speed.
        Re: Compact routers
        Pulled the trigger on the Dewalt....have never been disappointed with a Dewalt tool...
