Bought the new ORANGE 1/4 Sheet sanders last week and have been using them every day.
Did the engineers have a brain dump, the screws which hold on the base plate with foam have too large a head on them. As soon as the foam, which by the way starts to disintegrate within a week gets broken down at all the screw heads wear out the sanderpaper where they are located under it, and they also cause bumps in the finished product.
Also, the foam is not a memory type foam. It will wear in one spot and return it's shape if you do minimal edge sanding in the same position. We have not had any other sanders do this in such a short period of time.
Simple fix for Ridgid, change the screws and put some better foam on the base plate. Other that that, the sander handles well and is quite, which is a concern for us. It also is heavier than any other palm sanders we have used, but you do get used to it.
HEY, HELP outa new Forum guy RIDGID. Give me a fix. [img]tongue.gif[/img]
PS. by the way our shop has nearly every wood machine made by ridgid. By buying the products for years now and have had some great tech support.
The RackMan [img]smile.gif[/img]
