Ridgid 535 threader problem
  • Ridgid 535 threader problem
    I am having a problem making good LH threads on my threader. I am able to get good RH threads though. The problem with doing LH is the thread pitch changes after about 1" into the cut. Can anyone give some help here. I have already tried a brand new set of dies, but had same results.
    Tahnks.
    to cut left hand threads require a special die head.
    a #842 or mj-1 are designed for left hand threads. check your die head for this.
    one more note. if you post this in the plumbing forum, you will get much more input.
      Thanks Rick.
      I'll take a look at the die head.
      If that doesn't check out I'll post it in the plumbing forum.
