Will Batteries Work in Other Products?
  • Will Batteries Work in Other Products?
    Just wondering if the Ridgid 18 volt battery packs will work in other products from other manufacturers, ie, weed eaters, other tools, etc?
    Pritch-
    they would only if Ridgid made the tool. But they would not work in a Black and Decker weedeater
      Some tools use the same motor for different voltage tools.ex. 12v and 14.4 drills. This might not hold true for all companies. I would use rule of thumb. If it is same voltage and fits it will probably work. You stand some risk if you put a higher volt battery on a tool. It might work but it could cause it to have a short life.
