TS2400 Motor Squeal?
  • TS2400 Motor Squeal?
    I just purchased a ts2400 portable table saw and out of the box it seemed to run fine (no unusual noise).
    After ripping four 24" long 2x4's the motor now has a squeal as the blade spins up to operating speed, it does the same thing as the blade spins down. Although during operating speed- no squeal. I've used a couple of different blades- same thing with each of them.
    Have other experienced this? Something I can adjust to stop the noise? Is it defective and I should just return it a different one?
    Thanks in Advance
    themoz
    Make sure the blade is still tight. Sound like a dumb answer but it has happened before
      Motors don't usually squeal unless they've got a bad bearing, but belts often do. I suggest you check your belt tension.
      [ 07-19-2005, 07:02 PM: Message edited by: Lorax ]
      Lorax
        Hey Guys:
        Thanks for the leads on my squeal problem. BUT... the blade was tight (i've switched between a couple of different blades, making sure they where all tight after running the saw a bit- same squeal) and I may be missing something but this saw is a has a direct drive motor (no belt).
        Would your next diagnosis be the motor bearings?
        THANKS AGAIN!
