Blade Stabilizer Kit
  • Blade Stabilizer Kit
    I have one more question so I thought I should start a separate thread. I bought these: http://www.houseoftools.com/product.htm?pid=409671 and they do not fit the TS3650's arbour. Does the TS360 have an irregular arbour size or did I get poorly machined blade stabilizers?
    Quentin
    I would think it would be the shims if the blade fits
      I gotta agree with Wayne. All things being equal, if the blade fits and the stabilizer doesn't, you've got a defective stabilizer. An easy way to tell would be to lay the stabilizer on the blade and compare the hole sizes.
        I have Freud ones on my RAS B?C it does not change the depth of cut as on a TS . I think they make no difference and the reports I have read say the same,the blade design is the key.
        You must have a smaller hole in the stablizers if the blade fits.
