Holy Torque Batman
  • Holy Torque Batman
    http://www.ridgid.com/Tools/R6300-Im...%20/index.html
    Max Torque: 450 ft-lbs, that’s a lot of torque.
    Anybody know what the prices of the 12V and 14V impact drivers and the laminate trimmer are expected to be.
    Woodslayer
    The 14.4v impact is $179.00 from what I have seen, the right angle is $169.00. May vary in your area though.
      I have the Bosch 12V Impact Cordless and Torque is 850
      ft Lbs.
        You sure its not more like 87.5 ft. lbs
        Bosch 12V Impact
        Model Number 23612
        Voltage 12V
        Torque (in. lbs.) 1,050
        Weight (lbs.) 3.7 lbs. (including battery)
        RPM (loaded) 0-2,800
        Impact Rate 0-3,200
        Battery/Charger 1-Hour Charger
        Drive 1/4″ Hex
        Length 6.5 in.
          I hope so, cause I have a corded 120V AC DeWalt 3/4" drive impact wrench that is supposed to be 290 Ft/Lb. (I need it to get the lug nuts off my truck). If you can get 870 Ft/Lb from a 12V cordless impact wrench, that's really doing something. Most of the cordless ipacts I have seen are rated in In/Lb, divide by 12 to convert to Ft/Lb.
            There is this nasty bugger from dewalt DW059K-2
            300 ft-lbs of maximum torque to perform a wide range of heavy-duty fastening applications
            1,650 rpm/2,600 bpm for faster application speed
            Preferred rocker switch design for fast and easy fastening
            Comfort grip provides maximum comfort
            Durable magnesium gear case and all metal transmission for extended durability
            Heavy-duty impacting mechanism directs torque to fastener without kickback
            [ 12-13-2004, 09:21 PM: Message edited by: wbrooks ]
              WBROOKS
              you are right, not f. pounds but 1050 in.pounds
              as for the Bosch 12v Impact driver.
