Determining pressure washer model
  • Determining pressure washer model
    Picked up a running 3000psi 2.6gpm pressure washer for $25. Supposedly it needs a pump rebuild. I need to pick up some parts, but the model number is completely gone from the label. How can I determine model number and where is the best place to get parts? Thanks!
    Did you ever figure out where to find the model number?
      If it's a silver pump with a brass head, it's a RD80746. That pump is cheaper to replace than to rebuild.
      If it's a blue pump with a brass head, it's a CAT pump and is probably a RD80701.
        I have and rd80701. for so reason i cant find a replacement air filter. any suggestions on what i can use instead?
