Band Saw Circle Cutting Jig
  • Band Saw Circle Cutting Jig
    I built a circle cutting jig for BS1401. When cutting circles the blade pushes away from the work and bogs down the saw.
    I believe this is a pivot point placement problem. Where should the pivot point be positioned.
    Thank you
    Pivot point should be alligned with the cutting edge of the blade. You should use a narrow blade and you should 'round' the back side of the blade with a honing stone.
