Remome the chuck?
  • Remome the chuck?
    I must be doing something wrong. I need to remove the chuck on my 18v X2 and I can't seem to get it loose. I'm following the directions in the book. Is their a trick?
    Which step are you at?
    1. Tap chuck clockwise
    2. remove screw clockwise (left thread)
    3. remove chuck counter-clockwise
    Put the drill in low gear, this helps keep the motor from turning when doing above
      Got it. Just had to hit the hex key harder. Thanks.
