MS10500 rattles when slowing down
  • MS10500 rattles when slowing down
    Hello:
    I have a MS10500 saw that is approx 2-3 years old. Has been working great so far! A few weeks back a piece I was working on got sucked up into the blade guard and ever since the saw makes a horrible rattling sound when it slows down. It also seems that the blade may be vibrating a bit as it cuts. I've tried a new blade with no improvement. If you had to replace a part to fix this, which would it be???
    Thanks in advance.
    Mike
    If you have vibration with the blade,since you got it jamed you put pressure on the spindle,the flanges,or the bearing and bearing housing. if there is no flat spots on the flanges you very might have a bent spindle.
