TS3650 motor belt rubs
  • TS3650 motor belt rubs
    Hi,
    I put together my saw and have found that at blade angles nearing 45 degrees, the motor belt rubs slightly against the frame below it. When the blade angle is at 0 degrees, the belt has about 1 1/4 inches of clearance and this slowly disappears as the motor rotates around.
    Is anyone else getting this or am I just an assembly doofus?
    Thanks,
    Dave
