Ridgid R4510 slight wobble
  • Ridgid R4510 slight wobble
    My R4510 contractor table saw trunnion has a slight wobble when I raise or lower the blade. The wobble is not that noticeable when the motor is running but when I turn it off it can be noticed slightly as the blade slows down.
    Could kickback be a culprit on this issue? Possibly the kickback bent something on the trunnion or got an adjusting screw loose? The current blade is brand new, so it is not the blade causing the wobble, I checked. Is there a way to fix this?
    Maybe the kickback bent the blade? Is everything tight on the trunion?
      Paarker, it's not the blade because the blade is new and not the same blade I had installed previously.
