R84015 case fit an 18v combo drill?
  • R84015 case fit an 18v combo drill?
    does anyone know if the case for a R84015 drill will fit the hammer drill 18v from the 3pc combo? or are all the drill cases the same size?
    You can get an answer from RIDGID Customer Service @ 888-743-4333.
      Maybe. The drill will fit but the auxilary handle may not. Early in production the handle location was moved from the front of the clutch to the back. On my 84015, the case is specifically molded for the front handle. The newer style case (rear handle) is probably specific as well. You could probably verify that at HD. If storing the drill with the handle attached is important, you would need to find the appropriate case type.
