Router Table Extension Weight Too much?
  • Router Table Extension Weight Too much?
    I am planning to make a router table extension and mount it on my 3612 using aluminum angles. The weight will be distributed between the two rails. I am planning to use two 3/4 MDF with laminate top and bottom and hardwood edging.
    My question is, do you think this is too much weight to be held up by the two rails? I certainly do not want to damage the rails and cause them to warp or something. What do you think? Any suggestions to lessen the weight?
    Thanks..
    Won
    i could be wrong but the wing you speak of sounds like it weighs less than the cast iron wing installed standard!
