Ridgid R83001 (14.4v Cordless Drill) question
  • Ridgid R83001 (14.4v Cordless Drill) question
    Hello,
    I just received this cordless drill via an Ebay purchase. Once I had a charged battery on the tool, I gave it a quick test. From the owner's manual, I know that I should see sparks because of the electric brake, but should I be hearing a clinking noise as well (as if there is something loose inside the drill)?
    Thanks,
    David
    I don't happen to own this drill/driver but IIRC the noise you're hearing is normal and has something to do with the clutch mechanism I believe.
    ------- Henry Ford
      Is it a Dewalt drill? I have seen (or heard) the same problems from some of are guys. Will this shorten the life of the tool?
      Unless you are the lead Dog, the scenery does not change...
        **That noise is normal.**
        You'll notice it more in 2nd gear.
          Thanks for the information. Just started working with the drill last night and I was very impressed by the torque and balance. It's a heavy drill, but the weight is manageable because it's balanced so well.
          Regards,
          David
