Riser block for BS1400?
  • Riser block for BS1400?
    Anybody know of a 6" riser block kit that will fit this saw? I've heard of a Grizzly being used that required some fitting.
    The Ridgid kit is way to expensive ($125 when I called). I've heard of people finding them on closeout at HD, but no luck there, though I did get the saw and 1300 planer on closeout.
    Thanks!
    Try doing a search using "riser block" as the criteria. There have been many threads dealing with the Ridgid riser blocks.
      Where are you located?
        According to the tool acc. order sheets at HD, the riser blocks are $65. If Ridgid tells you more, maybe it's that they know the saw won't hold up to the abuse of a 3/4hp motor resawing a 12" thick board. In any event, they should say that if true, or just tell people the correct price.
        I've read on a few websites that the HF riser block actually fits the saw, and am going to try this weekend to find one for my saw.
          Jake
          I started a similar post here and over at the BTCentral forum. You can use the Grizzley H3051. Actually I order both the Grizzley and Jet riser blocks. The Grizzley is the cheapest ($45) and best of all the ones that will work. The only modification I made to mine was to paint the 6" block black, instead of the standard "Hulk Green"
          Actually, here's the link. It's a long saga that several of us went thru to come to the final resolve:
          http://www.bt3central.com/forum/topi...r,block,bs1400
          Good luck.
            Thanks Jason.
            I had seen that thread, but guess I didn't read all of it. I may have a line on a Ridgid riser for a reasonable price, but if that doesn't work out, I'll get the Grizzly.
            Ridgid also quoted me $67 for the fence, is that the regular price? I can get the Fasttrak for about $10 more, which includes the resaw guide. Is the Fasttrack a good fence system?
              Jake,
              I was in HD in Tewksbury, Ma yesterday and they had three risers on their closeout table for $35.
