4513 saw
  • 4513 saw
    I have a 4513 saw. Does anyone know if an Infinity flat top 1/4" kerf blade # 080-250 will over work this saw?
    Never seen one first hand but looking online it appears to me to be nothing more than a specialty 8" diameter dado stack. Meaning it's not a full width dado set like you would normally see with 13/16" capacity.
    So, IF the manual says you can use an 8" dado set with your saw there should be no reason you can't use this one as long as it doesn't exceed the dado capacity of your saw. That information will be in your manual and no matter what I or someone else tells you here that is the best place to get the correct information.
      https://www.manualslib.com/manual/96...13.html#manual Here is the manual and on page 37 exemplifies Bob D's point.
        The manual says 6"x 3/4" is max. for saw. From what I have read the infinity blade weighs 3-4lbs. I'm more concerned about the weight than diameter and width.
