Recently picked up a used 12 Volt drill. I've been unhappy with the chuck loosening on drill bits, so I'm trying to swap out the chuck and have run into issues.
I was successful getting the phillips screw out, but can't seem to get the chuck to unscrew. Using suggestions from the internet I put the direction switch in the middle. First I tried securing a large allen wrench, but it just spun the motor. I tried an impact driver, but either the motor spun or the chuck would loosen on the bit.
That's when I found I must have left the clutch on a low setting. When I tried to adjust it, it gets stuck at about the halfway point.
I didn't think the motor should turn in the middle section. Is something damaged or stripped? Did I make things worse by f-ing up with the clutch. Is the clutch seized? Or busted?
Am I up the creek, or can I salvage this?
THANK YOU!!
THANK YOU!!
