Originally posted by dadamssg
View Post
Alignment screw on 4514 table saw
Thanks Bob. Yep, it's pretty much exactly the same in my manual.
I've submitted the Contact Us form with my dilemma. We'll see what happens. I didn't get a confirmation that the message was received though. Hopefully it went through.
I guess you are referring to this section of the manual. This snip is from the R4513 manual, but I would expect your R4514 is very similar if not the same.
Yeah, not much to go on and no exploded diagram of the saw that I found in that manual. so you can't really see what that adjuster looks like. Sounds like it has a cam or eccentric lobe on it to make the alignment adjustment. But how much range it has can't say. I bet RIDGID Customer Service or Tech Support could. Your best bet would be to give them a call and they should be able to help you figure out why you can't get it properly aligned.
I noticed that the alignment of my brand new saw blade is off about a millimeter from measuring one saw blade tooth to the miter gauge, rotating that same tooth to the back and measuring again. The manual says to loosen a couple of allen screws a half turn and then turn the alignment screw until the blade is aligned. The problem is that turning the alignment screw only moves the back of the blade about half a millimeter. If i continue to turn the alignment screw, the alignment eventually gets brought back to its original position and i start from where i was. I would expect more room for adjustment than half a millimeter from the alignment screw. I'm never able to actually get the blade exactly aligned.
Do i have a defective unit? or is the alignment screw only good for half a millimeter of adjustment?Tags: None
