Ridgid Battery Adapters
    Originally posted by fixitright View Post
    Going to need new batteries for my Ridgid cameras. Heard Makita makes ones that will fit.
    That's what I've been using. 5amp makita batteries last longer than the ridgid.
    Rick
  • fixitright
    I purchased a Milwaukee adapter for old school tool platform to current battery platform on a sawzall . Work ok , but doesn’t click in tight.
    Also a Makita 14.4 to 18 for a propress tool. Same issue, doesn’t hold tight and with a high amp tool, you need to keep it pushed in tight.
    Rick
  • reConx
    started a topic Ridgid Battery Adapters
ID:	752604Click image for larger version
ID:	752603 Ordered two Ridgid battery​ adapters off Amazon. The overall build fit & finish was good. Some batteries required to be inserted firmly into the adapters until they clicked. This step improved with repeated use. All the tools Click image for larger version
ID:	752602 tested performed as designed. Instructions stated NOT to charge the batteries with the adapter and recommended removing the adapter from the battery after use. I will probably leave the adapter on a select tool(s).
