new to the band saw
  • new to the band saw
    got a hell of a price on a ridgid band saw display model. havent fired it up yet (still too cold here), but i am sure it will work great
    this is an elementry question i am sure...but i need some help here
    riser blocks to increase cutting capacity?
    how exactly do they work? are they a good idea? pros/cons?
    any feedback greatly appreciated
    I have one and it work good. You install a block on the back to raise the height of the saw. It also requires a longer blade, extenions for the guides. It adds about 6" to the cut you can make.
    You mostly need it for resawing.
    Steve
      do i need to do anything with the motor size to accept the larger stock and cut it well?
        Getting a bigger motor is really not necessary. Just keepng the stock that you are cutting in a secured manner and not forcing the item that you are cutting.
          ok
          finally got out to play with my band saw a bit. it was kind of cold out this way thus far. anyway i just went out to fire it up and make sure it works. followed all of the alignment steps in the manual (i bought the display model), and still, there is what sounds like the blade scraping against the plastic guide? cant seem to figure out where or stop it. any ideas?
