Robertson bit use in a Screw gun?
  • Robertson bit use in a Screw gun?
    Will a robertson bit work properly for depth setting when using a screw gun (decking/ drywall)?
    Thanks,
    gdeno
    I have used the square bit on decking with my screw gun, but never tried it on drywall. However, the principle of the screw gun is to release the drive when it reaches the proper depth, so there is no reason the type of screw would make a difference. HTH Jim
      Thank you...You have confirmed what I was thinking. Time to go get a deck gun.
