New TP1300LS in feed problem!!
  • New TP1300LS in feed problem!!
    I bought the TP1300LS thickness planer about 1 month ago. It is the first planer I have ever used. It was working great until today. I am hoping someone can help me determine what the problem is. When attempt to load the wood the rollers do not move the material through the planner. I can push the wood in and pull it out the other end, and the cutters do plane the wood. Also, if I raise the cutter heads I can see the roller moving. Any thoughts??? Thanks for you help in advance!
    Been there, done that!
    1. unplug the machine
    2. clean the rollers
    3. wax the tables
    4. carry on
    Lorax
