Ridgid batteries??
  • Ridgid batteries??
    Will my 14.4 volt Ridgid Impact driver accept 12 and 18volt batteries? Just curious as the charger says it will charge all 3. Anyone tried yet?
    Every Ridgid tool is powered by one voltage of battery. On your impact driver and drills it tells you the voltage near the bottom of the handle and on the sticker with your serial number. Even if you can get a larger battery to fit you could burn out your motor. The charger is the only universal accessory
    "Diplomacy is saying nice dodging until you can find a rock." Will Rogers
    "If a Monkey can do your job, are you in the right profession?
