Air compressor repair?
  • Air compressor repair?
    Hi all,
    Not sure if this is the right forum for this but maybe someone can help.
    I've got 2 Rigid twin stack compressors, 1 blew the piston out of the pump and destroyed the bearing the piston rides on.The other has a dead motor.
    I want to make one working compressor out of the two and have got them both torn down to just the motor housing with pump mount.
    My question is how do you remove the crank and bearing for the pump piston to get to just the motor?
    Any help would be really appreciated. Thanks!
