Power screwdriver
  • Power screwdriver
    What is the difference between a power screwdriver and a power drill?
    how it is used
    I power screwdriver, generally called a screwgun, holds bits with 1/4" hex shanks. It has an adjustible nozzle and a clutch. This allows the screws to be driven to a consistent depth. Though the motor keeps running, the drive stops at the correct depth. This is normally used for installing drywall.
    A drill will hold a driver bit just fine. The operator must guage the depth of drive for each screw. The clutch, if there is one, works completely differently.
    The clutch in a screwgun is effected by pressure applied against the bit, not torque, but applied pressure. The clutch on a drill is effected by torque, not applied pressure.
      big thom that is the best answer i think i ever heard of to this question
      9/11/01, never forget.
