mobile stand for Ridgid 15 inch drill press
  • mobile stand for Ridgid 15 inch drill press
    Has anyone found or made a solid mobile drell pres stand for the DP15501?
    My shop is small and need the ability to move my tools around.
    I use the Delta 50-345 mobile base on my 17" general which is larger and heavier than the Ridgid and it is very stable. I used 3/4" plywood as the base and bolted it to the mobile base then bolted the drill press base to the plywood
      Great! Thanks for the tip!
        I have this one; I don’t require much mobility out of my DP but find this easy enough for the occasional need.
        http://www.milwaukeehandtrucks.com/40119.html
        Woodslayer
