Problem with New Ridgid Tablesaw
  • Problem with New Ridgid Tablesaw
    I bought a new Ridgid tablesaw from Home Depot a couple months ago. Until today, no problems.
    I went to use the saw today and it stops when running a board through it. Nothing has changed, but it's just not getting any power. I checked the basics, belt tension, alignment etc, nothing obvious.
    I'm not sure what to do, I just bought the saw two months ago...
    take it back to HD and get a new one. You have 90 days.
      Does the motor stop? Are you using an extension cord?
        Open the inspection cover on the motor and check for a loose wire connection.
          The motor does not stop, but the blade does. I am plugging the saw directly into an outlet with the direct cord.
            Make sure the set-screws on the pulleys are tight. I don't know if there is a key in there (pulley to shaft) also, so check for that too.
            Lorax
