18 volt Ridgid R841150 drill
  • 18 volt Ridgid R841150 drill
    I recently replaced a motor gear box assy on my drill.
    I am having problems installing the clutch collar assy.
    Does any one have or know the procedure to reinstall the collar assy?
    I cant seem to find the breakdown on that drill but ;
    make sure your torque setting is at lowest point.inside the coller there should be grooves,if you setting is at the lowest point then slide your collar on around the 1 torque setting.with all other drill you have to do this with it out of the housing.after you get it on the clutch turn it and make sure it goes to the highest setting.then put it back in the housing.
    A fishing pole is the best cordless tool!
