metric nut drivers
  • metric nut drivers
    Does anyone know where I can find a 10mm nut driver/bit? The type that will fit & lock into a cordless impact driver. I have no trouble finding standard sizes, but can't seem to find metric sizes.
    Thanks
    Get a 1/4" hex drive to 1/4" sq. drive adapter and put it in your cordless drill. Then you can use whatever 1/4" sq. drive std. or metric socket you want.
    The adapter should be less than $2 at Sears, HD, Lowes, and ACE Hardware stores, and many other places.
    John Ruskin (1819 - 1900)
      I'm surprised your impact driver did'nt come with a hex to square drive bit.
      Once you get one, you can also buy a 1/4 to 3/8 adapter so you can use your 3/8 sockets as well.
        If you are close enough try Windsor
          come to think of it i have never seen that either, i sure hope you doin't need it magntized as what everyone here is telling you how to get what you want with adapters that should get the job done
          9/11/01, never forget.
            Those adapters work well in a drill/driver but from my experience they don't do as well in an impact driver. The first time I tried using one in my 14.4V impact driver the adapter broke in half. Thinking it might just be a bad adapter, I put in another and it also broke right away. Granted these were el cheapo adapters but a good one probably won't be cheap either.
            ~~Don't worry about old age; it doesn't last that long.
              Try a Snap-on or MAC tool truck - slightly expesive but top quality...
                found !
                northern tools
                metric and fractional made by GRIP
                  As Badger Dave,& DCDUDE mentioned, I would recomend going up to 1/2" square drive, and then you can use the heavy duty bits & tops that are good in an impact, or pneumatic tool. I recently had a (cheap & nasty) 13mm top explode in my (visor protected ) face, while using an impact tool, so a few dollars more might be well spent!
                    Thanks for all the ideas everyone. Truth is, I won't be using it in a impact driver. At work I frequently use a cordless screwdriver which has a impact style chuck(locks bit in place). Ideally I'd would like to find a 10mm magnetic nutdriver bit! Finding standard sizes is easy, but can't seem to find metric.
                      nutdriver
                      I just look under fasnall web site and did a search and they have a 10mm bit magnetic jeff
                        nut driver
                        also McMaster-carr page 2686 online catalog jeff
                          Thanks everyone! Finnally got what I was after at McMaster Carr.
